586,061 active members*
4,379 visitors online*
Results 1 to 7 of 7
    SIEMENS 810 PLC error, need PLC files
    Hi!
    I have CHIRON DZ18W with SIEMENS 810 CNC.
    The center build in 1992.
    I have the error screen and the first error (ORD 1) I remove (replace battery), but the second error (ORD 3) is present.
    Looks like I need the PLC files. Who can help me? Pllls.
    Mar 2010
    1852
    If you pulled the battery, you probably lost all commissioning data.
    I have an 810T, so maybe that will work. I'll attach it here and see if it works. I'll attach the PLC file (TEA2) and the full commissioning data, which has TEA1 and TEA2.
    Good Luck----Mike
    Mike
    Attached Files Attached Files
    Mar 2010
    1852
    I changed the file attached as the site would not take the PLC data by itself. The new file should have 5 parts to it. One is just the PLC data from my lathe for the 810T and the the other four files are the instructions for loading the the three required for commissioning. The PLC data is contained in the commissioning data.
    Follow the instructions to the letter(carefully).
    Mike
    Great thnx!
    I will try after weekend and let you know the results.
    Regards,
    The problem was solved today. The service center of Chiron send me all data for PLC.
    It is real the best service center I have ever seen!
    Regards to Chiron!
    Mar 2010
    1852
    :banana:
    Jun 2017
    I need your help as well
    I pulled the battery as well, I tried to follow this link to download the PLC files but Industry Area just says that the link is invalid, I would be grateful if there was some way that I could get a hold of these files, thanks in advance.
    Quote Originally Posted by Machineit View Post
    Good Luck----Mike
    Mike
  1. Chnc-1 with siemens controls error 2000
    By 1897Baldwin in forum Hardinge Lathes
    Last Post: 08-11-2013, 10:38 PM
  2. Siemens 840c error message
    By lesarcs in forum SIEMENS -> Sinumerik 840C
    Last Post: 06-17-2013, 03:14 PM
  3. Siemens 810M 1682 error code
    By mjhjenks in forum Controller & Computer Solutions
    Last Post: 12-17-2010, 04:26 PM
  4. Error message from Siemens 840 d/Hitrol
    By Ole Emdal in forum Norwegian
    Last Post: 12-08-2010, 09:56 PM
  5. Cinci Arrow w/2100 Siemens 611 error
    By cnccalgary in forum Cincinnati CNC
    Last Post: 09-28-2009, 10:29 PM
