586,069 active members*
3,410 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > "Breakout board & motor controllers" v "Stepper motor driver controller board"
    Oct 2013
    Question "Breakout board & motor controllers" v "Stepper motor driver controller board"
    Hi all, I'm new to all this and when I look around for the electronic side of CNC router world I see two options.
    The breakout board route looks more complicated but I'm guessing the ease at which you can replace parts is an advantage.
    The all in one driver controller board looks good to me but does it become a throw away solution if a controller burns out or some other disaster. If parts burning out aren't a problem then please let me know?
    I have no electronic knowledge and I'm looking for the safe option.
    Also if anyone can recommend a UK supplier with good after care I'd appreciate that.
    Regards
    Pete
    24221
    It is not one or the other?
    You can get away without a BOB but you need a servo/stepper controller of some kind if going the Mach P.P. route.
    There is outboard controllers that give you a little more flexibility such as Dynomotion, seeing as you posted in the Brain forum, which I believe is pretty much 'Brain Dead' now?
    Al.
    Albert E.
  1. Let's "Open Source" a SCR (And maybe VFD) Motor Controller CNC Interface!
    By TroyO in forum Open Source Controller Boards
    Last Post: 10-08-2013, 10:10 PM
  2. "bad internal voltage" error on step motor driver, Please help!
    By alexofcharmcity in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-16-2013, 08:46 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. First build 8020 60"x24"x5" Board Shaper
    By dlyork in forum DIY CNC Router Table Machines
    Last Post: 09-07-2010, 02:32 PM
  5. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
