586,102 active members*
2,527 visitors online*
Page 162 of 422 62112152160161162163164172212262
Results 3,221 to 3,240 of 8431
  1. #3221
    Sep 2013
    11
    its machining centre which is operated by computerised instruction via computer.
    i have an alarm c on y axis drive now. machine does nt calibrated due to this alarm.
  2. #3222
    Dec 2013
    Just signed up, obviously. Wanting to learn more about CNCs
  3. #3223
    Dec 2013
    Quote Originally Posted by bentok View Post
    Hello all together.
    Hello
    My name is Eugen,I come from Canada
    I'm Woodworking Engineer.
  4. #3224
    Sep 2013
    11
    hello
  5. #3225
    Dec 2013
    4
    the learning curve is going steeper =;D
    Ric
  6. #3226
    Dec 2013
    11
    Hi just here to learn some cnc basics, in the process of getting a machine should be here in a few weeks.
  7. #3227
    Dec 2013
    11
    Its a 2005 fulland 550 flg machine center
  8. #3228
    Wink Hello
    Hi everyone.
    I'm working in local joinery on a CNC machine bima300 from IMA.
    I'm also an instructor with a certificate.
    I'm here to learn more about CNC machining and programming.
    Also I'm interested in metalworking since so far I've been working only with chipboard.
    Apart from bima300 I've been also working on
    -SCHELLING Beamsaw FM 430
    -Homag weeke BHX 055 Optimat
    -Tekna TK446/2 CNC for aluminium
    -IMA Compact S Edgebander
    -Grass Combipress
    I hope to learn more and help others do the same.
    Cheers.
  9. #3229
    Dec 2013
    41
    I'm a long time member from the early days of the zone that lost track of my password. Because the password reset feature flat out does not work after months of trying I am establishing a new account.
  10. #3230
    Dec 2013
    Hi
    I'm a real rookie with cnc but have a bunch of years in the manual way.
    //K
  11. #3231
    Dec 2013
    50
    Hey folks,
    I have been reading and following on and off for a while, mainly seeking some help, finally decided to join in a little, so here I am. I'm Scotland based, I'm into Electronics and enjoy Woodworking, so CNC is an, um, natural progression, at least that's what I keep telling my fiancee
    If anyone needs some electrickery help, shout out and I'll see what I can do
  12. #3232
    Dec 2013
    10
    Hi Friends, how are you ??
  13. #3233
    Dec 2013
    hello everyone my name is ian and I am a cnc programmer in glasgow
  14. #3234
    Dec 2013
    50
    Quote Originally Posted by ianbax61 View Post
    Good to know Ian, I'll be calling for your help at some point no doubt
  15. #3235
    Dec 2013
    hi i am alexander
  16. #3236
    Dec 2013
    Hi: I am Mike and have converted two cnc mills of 1985 vintage that the electronics died on and am using Mach 3 and geko drives. I am working on a third machine that has a tool changer and servo motors which is a new area for me.
  17. #3237
    Dec 2013
    Hi, I just needed to register to see some attatchments.
  18. #3238
    Quote Originally Posted by maqboolahmed130 View Post
    Do you have a user manual or some instructions?Maybe you can try to check the problem and solutions in it.
    or have you turned the right switches before processing, such as the switch of servo motor. Cause I have no idea what machine you are using, I don't know whether this tip can help you and whether there is a servo control switch on your machine.
    But hope everything will be OK!^_^
  19. #3239
    Dec 2013
    5
    hi my name hendry owner rr
  20. #3240
    Dec 2013
    35
    hi, i am jakson and here i am newbie in this forum. So please help me for forum discussion.
  1. Thread spec for camera lens filter thread
    By cmays in forum MetalWork Discussion
    Last Post: 07-20-2016, 10:43 AM
  2. Thread Mill Wizard - Slanted thread produced
    By ngr1 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-22-2012, 07:23 PM
  3. Special ID thread. sp-400 "M" type thread 8TPI
    By Captain Crunch in forum MetalWork Discussion
    Last Post: 04-05-2012, 09:39 AM
  4. acme thread combos and thread mixing
    By calaber40 in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 02:04 AM
  5. Thread mill external NPT thread
    By cutting edge in forum MetalWork Discussion
    Last Post: 09-15-2008, 02:33 PM
