586,590 active members*
2,368 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Need help with simultaneous 4th axis
    Oct 2013
    Does anybody know how to machine a Helix, simultaneously with a 4th axis,on the outside of a 400mm dia part using FeatureCam. I have a solid model imported from solidworks, is there an easy solution to this? Am I just not clicking the right buttons?
    Oct 2013
    Apr 2013
    25
    Yes, make a groove, set your parameters. Make sure when you start/import the part 4 axis rotary index is on on the appropriate axis. Make the groove, set the angle to the helix angle, and select wrap feature around index axis.
    Oct 2013
    Thanks Shamanj, got it sorted out
    Apr 2013
    25
    Re: Need help with simultaneous 4th axis
    Yeah I'm a bit of a gun at 4th axis. Send my the model and I'll see whats up. You can machine with the Y offset at a particular location. Look for Y offset in the help dialogue
  1. Need help with simultaneous 4th axis
    By mgmcnc in forum FeatureCAM CAD/CAM
    Last Post: 10-24-2013, 03:53 AM
  2. PP for heidenhain 426 5 axis simultaneous
    By strupi in forum OneCNC
    Last Post: 09-19-2012, 05:02 AM
  3. 4 axis simultaneous milling
    By svarzaru in forum FeatureCAM CAD/CAM
    Last Post: 07-05-2012, 05:33 AM
  4. simultaneous 4th and 5th axis work
    By jess fuqua in forum Mastercam
    Last Post: 06-23-2010, 02:15 PM
  5. simultaneous 4th and 5th axis work
    By jess fuqua in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-11-2010, 04:51 PM
