Fast Spindle - Who has Done It
Ok, as near as I can tell the bearings in the Taig spindle (or similar ones I can buy elsewhere) are rated for upto 17K with grease or 24K with oil mist. I ran the stock spindle at 10K for atleast a thousand hours and its still basically ok, so that doesn't surprise me too much. I wanted more speed though for faster production with small cutters in aluminum. I have a couple thousand more hours running various routers as spindles instead. They definitely can remove material a lot faster, but the nose bearings overheat and burn up when doing long jobs that use a measureable portion of their horsepower.
The stock spindle has a couple problems. Low horsepower and lower top speed than I would like. I can't drive a modest cutter hard enough to take advantage of its size for a decent material removal rate, and I can't spin a smaller cutter fast enough for a decent material removal rate. AND its heavy. That assembly with that fairly nice 1/3 HP brushless motor weighs in at a whopping weighs in at 15 pounds 12 ounces. The weight is great for taking up backlash in Z, but its hell on rapid speed which kills overall production rate when doing complex 3D machining.
The routers have their problems too. A Bosch colt has the horsepower for anything I would ever do with a Taig and the speed, but the heat from heavy cutting will overheat the nose spindle and melt the plastic nosebearing holder. Its light though. Even with the custom aluminum mounting bracket I made for it the total assembley is less than 4 pounds. Rapid speed is great, but backlash is an issue because there isn't as much weight to hold it against the threadss I have to keep the Z dialed in before everyjob. A Porter Cable router is better, but I have still cooked nose bearings. If I only rarely cut aluminum, and mostly cut wood and plastic either would be fine.
I propose a compromise. Use a small router as a drive motor for the stock spindle. Use maybe a 2:1 pulley reduction to drop top speed down to about 15-16K (depending on router choice) and increase torque so horsepower is never an issue. It would be lighter so rapid speeds would still be good have a proven spindle bearing setup. It would not transfer any heat to the motor bearings from cutting, and it would be modestly faster. According to FS Wizard calulations 5000 rpm makes a substantial difference in feed rate and material removal rate. The spindle bearings appear to be mounted directly in the aluminum block which helps with heat dissapation.
I suppose a chinese spindle (or Ugra spindle at much more money) seems like a good alternative, but it adds both spindle and VFD costs to the equation. Most VFDs in this size like 220 3ph, although 1:3ph and 110:220 VFDs are available for 1HP and under applications. I'ld like to keep it a simple 120V machine. The VFD stuff doesn't bother me though. I do have two VFDs inside the cabinet in my big mill working fine. One drives the 5HP spindle motor, and the other runs the motor cooling fan at low spindle speeds.
So who is running a Taig spindle over speed, and how long have you been doing it? What type of cutting?
Its all just thinking out loud right now...
Bob La Londe
http://www.YumaBassMan.com
