These look like VFD's as I mentioned earlier, you have the option of 1ph or 3ph in but it look like they are all 3ph out, which as I suggested you would have to use two phases out only.
These have wire terminal in/out so for input you need a power cord from the VFD and a wall socket on the other end.
You notice the 1ph in has L1 L2/N, so the neutral goes to L2.
Again the output is hardwired which you would need to attach a socket outlet to.
Don't forget to attach the ground to the inverter and the output socket.
Do not set them to anything but the correct frequency for Capacitor start induction motors.
Keep in mind that with this set up although you will have a ground, you will not have a grounded neutral to the output socket, due to all three phase are above ground.
Al.
Albert E.
