586,069 active members*
3,402 visitors online*
    Jul 2013
    FANUC Z AXIS SERVO AMP
    HI,
    I HAVE A HORIZONTAL MILL AND BORE MACHINE, FANUC 16M CONTROLLER. THAT HAS A '414 SERVO ALARM Z AXIS DETECT ERROR.' INSIDE THE CABINET THE SERVO AMP FOR Z AXIS HAS AN ALARM CODE OF '1' ON IT. ACCORDING TO ALARM MANUAL I BELIEVE ITS A LOW OR HIGH VOLTAGE ISSUE. ANYONE KNOW HOW I CAN TROUBLE SHOOT OF FIX THIS PROBLEM.
    THANKS SCOT
    Aug 2007
    793
    could you measure voltage on incoming terminals?
    if it is OK the problem may be in comparator inside the drive
    let us know the model of the drive
    Quote Originally Posted by SCARSON View Post
    HI,
    THANKS SCOT
    Check your cable from driver to servo motor thats the problem.
    Sent from my iPad using Tapatalk - now Free
    Aug 2007
    793
    I forgot to add
    if alarm occurs during the operation, the problem may be with discharging transistor or resistor
  1. Fanuc Om-417 X Axis Servo Alarm
    By intermax in forum Fanuc
    Last Post: 05-11-2022, 11:55 AM
  2. Fanuc 6MB with X Axis 401 Servo Error
    By dbrus38 in forum Uncategorised MetalWorking Machines
    Last Post: 01-15-2013, 04:55 PM
  3. Z Servo Axis 434 Alarm on Fanuc 6M
    By barchdesigns in forum Fanuc
    Last Post: 09-16-2009, 06:56 PM
  4. Fanuc 18i servo axis alarm2
    By wanchai101 in forum Fanuc
    Last Post: 02-13-2007, 04:52 PM
  5. Fanuc 18I Z axis servo Alarm 410
    By Ninus in forum Fanuc
    Last Post: 09-22-2006, 05:16 AM
