586,065 active members*
4,795 visitors online*
    Aug 2013
    Another DIY DC servomotor project.
    Hi all, first post.
    I am trying to convert a DC motor into a servomotor, too.
    Up today, encoder is delivering a bounce free output running shaft at 1500 rpm.
    Next stop, is try it at 3000 rpm to see if I can keep a noise free output from Schmitt Trigger .
    Then add quadrature and HOME gap detector to the wheel.
    DIY servomotor Playlist:
    DIY SERVOMOTOR - YouTube
    Questions and advices, are wellcome.:banana:
    24221
    That seems a fairly low resolution (50p/rev) if the intent is CNC application?
    Al.
    Albert E.
    Aug 2013
    Yes, its a CNC appliation, thanks for your reply.
    Encoder wheel has 200 PPRs, and gives a pulse around 180 microsec.
    Added another video showing pulses with scope.
  1. Servomotor refurbish
    By BgKai in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-30-2013, 10:08 PM
  2. West Amp Servomotor help
    By johnd in forum Servo Motors / Drives
    Last Post: 12-11-2008, 10:20 PM
  3. Servomotor
    By Alex S.A in forum Servo Motors / Drives
    Last Post: 06-10-2008, 12:50 PM
  4. SEM SERVOMOTOR Wanted
    By joesimmers in forum Servo Motors / Drives
    Last Post: 02-19-2007, 02:52 PM
