586,096 active members*
3,164 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > I need to clamp a very small round rod to CNC mill, any ideas?
    May 2013
    455
    Hey everyone, Pretty new to machining.
    I have an aluminum rod that is 1/2" thick, and about 1.5" long.
    I need to do some machining on about 8mm on either side of it, and some drilling.
    I am struggling to find a good way to clamp this to my bed or my vise.
    I tried making a small clamp by basically cutting a 1/2" thick piece of 2" x 2" aluminum and drilling a hole in the middle with a 1/2" drill bit. I then cut it in half and screwed and tapped some holes to connect both sides of the clamp.
    It works OK, but I am having a very hard time getting it perfectly squared up.
    Anyone have any other ideas?
    Jan 2006
    2985
    If the V block is too long, machine it down until it is the length you need.
    A picture of your part would help to suggest hold down methods.
    Matt
    Mar 2011
    525
    Cut and drill another block but this time only slit one side instead of cutting it in half. Place the block in a vise, insert your part, tighten.
    Kelly
    www.finescale360.com
    Jan 2004
    3154
    Clamp it end to end in the vise
    www.integratedmechanical.ca
  1. Questions -- Small CNC Router with VERY SMALL Work Area, Ideas?
    By Building in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 11:36 PM
  2. Looking for small clamp ideas
    By LockTech in forum MetalWork Discussion
    Last Post: 11-29-2010, 03:29 AM
  3. Looking for ideas for a small mill DXF files needed
    By Fixittt in forum Benchtop Machines
    Last Post: 08-21-2007, 06:21 PM
  4. HARBOR FREIGHT small round column mill to a square column conversion.
    By motomitch1 in forum Vertical Mill, Lathe Project Log
    Last Post: 12-01-2005, 05:24 PM
