I have found with some version of Mach3 and the smoothstepper, backlash com will work. I am talking of 4th an 5th axis here.
I have not found a version of Mach3, where backlash comp AND homing will work.
I have had backlash comp, OR homing, but not both!! Many versions tried, all the way to the latest 066. Grr!! And that was 2800K from home.
It was USB smoothstepper. And I wished the escape key would work like the reset button. Just stop, and not give data over-run message.
Tried different plugins. Documentation is LACKING in the area of trying to some serious work.
Speed is fine. MUCH faster than LPT port.
All the different versions, but which one to use. Recommended 050 was much worse than other. 062?? sucks 066. no better. wtf?? grr!!
