586,042 active members*
3,894 visitors online*
Results 1 to 6 of 6
    Aug 2011
    77
    small spur gears 100
    Looking to make 100 small spur gears about 3/8 dia and about 1/8 of gear with bearing surfaces on both ends but I woud just blank them out
    so all I would need is the teeth cut material is steel
    the other option is to cut long blanks and then I will just part them off in a lathe and finish the bearing fits
    Oct 2009
    14
    Checkout sdp-si.com(stock drive products) they have a good selection,
    or macmaster-carr I've bought pinion stock from them before.
    Sent from my MOTWX435KT using Xparent BlueTapatalk 2
    Aug 2011
    77
    Ok have more info pressure angle is 20 deg and they are metric module .6
    Material would be either 4140 or 4340
    100 w 14 teeth
    100 w 12 teeth
    Aug 2011
    77
    Thanks for your help I have looked all over the net for these in blanks and can't seem to find them ANY info would be a great help
    Also might be interested In a gear shaper if the price is right and in oregon some where
    Apr 2012
    23
    Please PM me if you still need these parts made. I have several questions and options for completing your project.
    Your PM box is full.
  1. 2 small metric spur gears 27.5mm od.
    By diyengineer in forum RFQ (Request for Quote)
    Last Post: 08-22-2012, 12:58 AM
  2. Spur gears
    By kenny wright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-03-2012, 05:01 PM
  3. Need help calculating spur gears
    By gharryh in forum MetalWork Discussion
    Last Post: 12-02-2010, 08:51 PM
  4. Spur Gears
    By warossignol in forum Mini Lathe
    Last Post: 06-09-2009, 04:30 PM
  5. anyone using Rack and spur gears
    By kfranklin in forum Linear and Rotary Motion
    Last Post: 05-10-2007, 02:43 PM
