586,082 active members*
3,602 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > New Haas Super Mini Mill (Odorless Coolant)
    Jun 2013
    34
    Hi Everyone,
    I recently got a new Haas Super Mini Mill for in-house prototyping, and it is amazing! I am familiar with cnc milling, but I don't know much about cutting fluid. My first instinct would be to buy the first cutting fluid I see on grainger or elsewhere, but I really need an "odorless" coolant so I don't stink up the rest of our facility with the scent of oil. Does that exist? Is semi-synthetic coolant odorless? I was looking at TRIM products, but I am not sure.
    I would appreciate any advice on coolant selection.
    (P.S. I would like general purpose fluid for aluminum, and steels)
    Thanks!
    Jul 2005
    12177
    Practically all the water mixed coolants are odorless when they are fresh. Practically all the water mixed coolants will have a very obnoxious smell when they are stale and contaminated with tramp oil. Also even when the coolant is fresh you can get some 'odor' because the machine creates a very fine aerosol mist that escapes from the enclosure.
    If it is really important that you do not contaminate the rest of your facility you need to get a good mist extraction system that collects the aerosol, a good tramp oil separator to keep that to a minimum and install either a small bubbler to keep the coolant mix well oxygenated or a small pump that constantly circulates the coolant for the same result.
  1. Engraving on an Arc using Haas Super Mini MIll
    By chop5280 in forum Haas Mills
    Last Post: 02-25-2015, 09:36 PM
  2. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  3. HELP!! Haas Super Mini Mill
    By CountBraden in forum Haas Mills
    Last Post: 07-07-2008, 12:20 AM
  4. HAAS Super Mini Mill
    By Ford25 in forum Haas Mills
    Last Post: 09-07-2007, 02:01 PM
  5. Super mini mill/coolant tank
    By taylors in forum Haas Mills
    Last Post: 02-20-2007, 02:33 AM
