586,116 active members*
3,280 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Question about 2005 and 1605 Ball Screws
    Aug 2010
    278
    I had a question, when i use 2005 ballscews, instead of a 1605, do I need a lot more torque to move it. My thought train was this, since there are more balls packed it would offer a larger resistance, also to go one more, if i use double nuts does it add a lot?
    I am going with 283oz-in closed loop stepper system from leadshine for a fix gantry version mill.
    Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
    Nov 2009
    4415
    The numbers just refer to the diameter of the screw. With 283oz steppers, you wont be taxing a 1605. Unless you just like bulk I would save my money. Most of use are running the 1605 on X & Y of our 0704's, the 2005 for the Z. IIRC the 5 at the end refers to 5 revolutions per inch but I could be wrong there (the more I think about it, being a metric screw. It could be 5mm per revolution?).
    The quantity of balls really just effects the load carrying ability, more balls , more load. Regarding effort to turn the screw, there shouldnt be much difference. Not enough to make a stepper lose steps or anything.
    In regards to double nutting and the extra effort that may require. It would depend on how much preload you put between the 2 ballnuts.
    Apr 2005
    419
    Both screws have 5mm pitch so the torque required will be similar.
    Double nuts does make the screw slightly harder to turn, but it is really nothing compared to the friction of dovetail ways, or the weight of the Z axis.
    Aug 2010
    278
    Thank you for the answer, yes the 2005 ball screw means 20mm diameter and 5mm pitch (lead) so at one revolution the ball nut moves 5mm. I will not be using dove tails, on all axis I will be using linear guide rails from HiWin, the heavy duty rails with blocks. For the Z axis weight it will be the carriage and the 80mm High speed spindle with ATC.
  1. Quick question about ball/acme screws
    By gearsoup in forum DIY CNC Router Table Machines
    Last Post: 03-21-2011, 03:52 AM
  2. Question about the chinese ball screws....
    By gearsoup in forum Linear and Rotary Motion
    Last Post: 10-06-2010, 11:25 PM
  3. Ball Screws or Not That is the Question
    By Woodenspoke in forum Benchtop Machines
    Last Post: 11-02-2006, 03:21 AM
  4. Question of keeping Ball Screws Clean
    By widgitmaster in forum DIY CNC Router Table Machines
    Last Post: 10-06-2005, 02:16 AM
  5. question about ball screws
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 10-04-2004, 07:58 AM
