586,110 active members*
3,316 visitors online*
Results 1 to 6 of 6
    Hitachi Seikos 3 SLBUS error
    Hi!
    I have Hitachi Seiki 3 (1994).
    After the switched on I found error message in Maintenance LCD (see in attach).
    I suspected the SPHCT board. Can anybody help me to solve this problem?
    Jun 2004
    511
    Hello,
    I had this problem just last week. On my machine the power supply that is at the bottom of the panel with the Fanus screen was bad. If it is OK it will have four green LEDS on. Open the the door with the Seikos screen on it and look all the way on the bottom of the panel to your left.
    Jun 2004
    511
    Dont unplug the boards in the Seikos unit or you can loose its memory.
    Quote Originally Posted by ifixcnc View Post
    Hello,
    Are you mentioned about this power supply? I found it is not worked.
    Jun 2004
    511
    Thats the one. Make sure it has 200VAC in at the bottom right plug. If it does and the green LEDs are not on it is bad.
    The problem solved.
    The key was in power supply resistor. 5W 20 Om resistor was broken (unclosed circus). After the replacment of this resistor, power supply became ready for action.
    No 800 Euro, only 10 cents.
    The photo of resistor is in attachment.
  1. Hitachi seiki seikos III
    By jam-man in forum Controller & Computer Solutions
    Last Post: 02-23-2013, 02:52 PM
  2. Hitachi seiki seikos III
    By jam-man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2013, 10:43 PM
  3. Hitachi seiki seikos III
    By dungvp in forum DNC Problems and Solutions
    Last Post: 11-19-2012, 05:45 PM
  4. Hitachi Sieki VM 40 PC not ready-slbus error
    By CJMFG in forum DNC Problems and Solutions
    Last Post: 04-09-2011, 12:00 PM
  5. Hitachi Seiki Seikos III Help
    By Andy177 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-24-2010, 05:46 AM
