586,112 active members*
3,110 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Auto reversing tapping head
    Nov 2012
    59
    Ok so I just picked up a really nice tappmatic and want to use it on my Tormach.
    How in the world do I set sprutcam up to feed at one speed and then x1.75 the feed out of the hole?
    Any one use a self reversing tapping head in sprut?
    Thanks for any help!
    Nov 2012
    59
    from looking it over, seems like I need to use "Drilling with chip removing cycle " I have seen with a TC tapping head that some guys dwell for .3 sec? is it the same for a tappmatic?
    Jun 2006
    3063
    I think that you would just use the standard SprutCAM tapping cycle. IIRC, the tapping head has an internal gear system which spins the tap faster on retraction then it does while feeding. Your feed rate (both in and on retract) should be (spindle speed)/(thread pitch). I haven't actually used a Tapmatic head, but that's the way my Procunier head works.
  1. Tension/Compression vs. Reversing tapping head
    By apeman88 in forum Tormach Personal CNC Mill
    Last Post: 07-29-2011, 12:30 PM
  2. Reversing Tapping head vs Tension/Compression tapping Head
    Last Post: 01-25-2011, 03:39 PM
  3. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  4. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
