586,655 active members*
3,489 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Newbie to CNC needs help to setup please.
Results 1 to 7 of 7
    Oct 2013
    9
    Hi guys,
    Up until now i've been getting a local company to do my machining of small metal parts for my business. I've now taken the plunge and bought a small 3 axis milling machine with 3 motors attached. The guy who sold it knows nothing about it as the owner moved to India and is not contactable.
    Each of the 3 motors has a cable with 4 wires inside. This is all the information I have.
    The unit is very similar to this: Syil X2 CNC Milling Machine | eBay
    Am i correct in assuming that all i now need to have a cnc controlled mill, is to connect a PC (with Mach3 software) via a small interface like this? 3 Axis CNC Router TB6560 Stepper Driver + Display + Control Pad + Aluminium Box | eBay
    Many thanks for your help in advance!
    alan
    Apr 2004
    5742
    You're basically correct, but many people on this forum have had problems with that particular control system. Here's an example of a thread that talks about them: http://www.cnczone.com/forums/genera...pdated-54.html
    If you want to explore the fascinating world of electronic trouble-shooting (a major hobby around here) investing in one of those would be a good place to start. Otherwise, you might think about getting a Geckodrive G-540 with a 48v power supply.
    Andrew Werby
    www.computersculpture.com
    Oct 2013
    9
    Thanks for your advice Andrew! I just checked out your website, very nice works of art!!!
    My main objective is to get this milling machine up and running as quickly and as cheaply as possible. In your expert opinion, do you think i'd be better going for the 6560, or the G540?
    Also, i'm thinking of making a little setup like this guy: DIY Dedicated Mach3 CNC Control Panel - YouTube
    Any thoughts on this?
    thanks again, alan
    Oct 2013
    9
    I forgot to post the details of the 3 motors, there is a sticker that says "Hybrid stepping motor - AC5707645251 - 2005-02-23-60UK"
    Does this mean the motor is AC and was manufactured on the 23rd of Feb 2005?
    Oct 2013
    9
    thanks again, alan
    - - - Updated - - -
    Also, i'm thinking of making a little setup like this guy: http://www.youtube.com/watch?v=KvhJj1yzqks
    Apr 2004
    5742
    Thanks for the kind words about my art work, Alan. That looks like a fairly standard 23-frame DC stepping motor to me. I've attached a PDF with some specs on it. I thought I'd expressed my opinion about those two controllers in a fairly unambiguous way, but maybe I could be clearer yet: avoid the TB6560 like a loathsome disease; get the G-540. That Chinese thing is certainly cheaper, but if you put any value at all on the hair you won't be pulling out by the handful, spend the extra money.
    That Mach3 controller looks like a nice piece of work, which is more than I can say about that guy's videography...
    Andrew Werby
    Attached Thumbnails Attached Thumbnails 180NcmStepperMotor6mm.pdf
    Oct 2013
    9
    Thanks Andy, i appreciate your time!!
  1. newbie first cnc setup and stuck HELP!
    By school sweeper in forum DIY CNC Router Table Machines
    Last Post: 03-30-2013, 11:41 AM
  2. Newbie Question on Setup
    By buddym in forum Mach Mill
    Last Post: 11-11-2006, 02:20 AM
  3. Newbie setup question
    By steve_goldsmith in forum Benchtop Machines
    Last Post: 10-29-2006, 03:56 AM
  4. Newbie Setup Help
    By shockflyer48 in forum DIY CNC Router Table Machines
    Last Post: 10-26-2005, 12:45 AM
