I need to drill a .30" x 13.5" hole into 4140 stock. Ive been reading up on gun drilling and it seems to be if you're over 20:1 you need to gun drill. If I drilled 7.25 in one end and 7.25 from the other and met in the middle would this work? I'd be at 25:1. If I went SLOW and pecked away at it would I be ok? The hole would be finish reamed anyway after the initial boring. Any advice would be appreciated.
