586,071 active members*
3,965 visitors online*
    Dec 2005
    141
    Best Way to Wire Steppers
    I am running KL-4030 drivers with 8 wire 425oz/in steppers (Also from keling) and i am curious, what is the best way to wire the steppers to get the most torque?
    Bipolar (Series)
    Bipolar (Parallel)
    Unipolar
    Here is the wiring guide from Keling
    http://www.automationtechnologiesinc...H286-20-8B.pdf
    Mike
    Jan 2010
    2141
    The KL-4030 is designed to drive bipolar motors, so you would not want to use the unipolar hookup.
    That leaves you with the choice between the bipolar parallel or series hookup.
    Your stepper motor has a somewhat high inductance in the parallel configuration, but a very high inductance in the series configuration.
    From the standpoint of achieving best torque at higher speeds, within the limitations of your driver, you would probably be better off going with the parallel hookup.
  1. 16 awg speaker wire for steppers?
    By 3Dsigns in forum Stepper Motors / Drives
    Last Post: 10-23-2013, 04:21 AM
  2. 8 wire steppers connection
    By michel colonade in forum CNC Machine Related Electronics
    Last Post: 02-17-2012, 07:45 PM
  3. Shielded wire for steppers, or not?
    By JanHenning in forum Gecko Drives
    Last Post: 03-09-2008, 02:29 AM
  4. 4 wire steppers
    By Gus_452000 in forum Stepper Motors / Drives
    Last Post: 09-19-2007, 06:51 PM
  5. Wire for Steppers
    By ger21 in forum CNC Machine Related Electronics
    Last Post: 06-05-2003, 06:24 AM
