586,035 active members*
3,828 visitors online*
    Apr 2011
    95
    tapping speed
    can anyone recommend a speed to run spiral taps at. we mainly use 6x1mm, 8x1.25mm and 10x1.5mm. we are using compression/tension type holder
    thanks
    Jan 2010
    107
    In steel i always use about 10 surface meters pr minute - so M6 is 500 RPM - M8 is 400 RPM - M10 is 300 RPM.
  1. mv653-106 high speed tapping question?
    By ceaser902 in forum Mori Seiki Mills
    Last Post: 01-11-2012, 01:00 PM
  2. Spindle speed control for tapping.
    By greeder88 in forum LinuxCNC (formerly EMC2)
    Last Post: 05-08-2009, 12:00 PM
  3. rigi tapping feed speed equasion?
    By stuby in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2008, 09:24 PM
  4. Spindle Speed for tapping 1/4-20 holes.
    By Loading in forum MetalWork Discussion
    Last Post: 08-17-2006, 03:28 AM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
