586,461 active members*
3,681 visitors online*
    Jan 2011
    10
    Fanuc 21i-M macros disabled?
    Hi Guys
    I recently got some machines with a GE Fanuc 21i-M control...
    I am familiar with macros and have no problems on any of the other machines I have...
    However this machine, I cannot do anything macro related.
    I have tried #3006=1(xxx), #2=5., #550=#2011 and a whole bunch of other simple macro commands. Each time, the machine goes to alarm 009(Illegal address input).
    I have come to the assumption that the macro function was disabled in parameter?
    Is that even possible?
    Anyone know what parameter will re-enable it?
    I have spent hours going through the operators and parameter manual with no success, even though it shows the function clearly in the operators manual...
    Can anyone shed some light on this?
    Claudio
    Solrac Engineering CC
    May 2013
    128
    the problem is it that you have to assign the macros for as per ladder or to co relate with Ladder
    Jan 2011
    10
    Thank you for the info... So basically I will have to do some PLC modification?
    2932
    User Macro B is an option. You should contact GE/Fanuc for pricing.
    Jul 2010
    118
    if you do not see the MACRO soft-key under the OFFSET/SETING screen macro B option is not active.
    this MACRO screen/option has nothing to do with the pmc.
  1. GE Fanuc Series 15-M macros
    By kthompson in forum Fanuc
    Last Post: 01-08-2013, 02:52 PM
  2. Replies: 5
    Last Post: 06-13-2012, 01:49 AM
  3. FANUC 0T-C / P-Codes and Macros
    By Minesterran in forum Fanuc
    Last Post: 01-31-2012, 01:01 PM
  4. fanuc 6mb macros
    By beekeeper in forum Fanuc
    Last Post: 08-12-2010, 09:41 AM
  5. Need Custom macros for Fanuc 3M
    By brgrii in forum Fanuc
    Last Post: 07-23-2006, 02:30 AM
