586,457 active members*
3,453 visitors online*
    Aug 2013
    5
    Fan , blower , connection , help
    For my shop I want to install a air filter system .
    I found a fan , witch looks strong enough , but I am not sure how to connect it.
    There are 4 wires from the motor and one earth. There is also a capacitor that comes out off the motor.
    The fan was previously used for a air heating system as a blower.
    On the unit is a label : sonitec SA Nivelles , google gives almost nothing.
    The wires are , Red-Black-White and blue .
    Ohms :
    red-black = 17 Ohm
    red-white = 34 Ohm
    red-blue = 10 Ohm
    black-white = 20 Ohm
    black-blue = 10 Ohm
    white-blue = 27 Ohm
    Can somebody help me out ?
    Aug 2013
    5
    Solved, it is a three speed motor, white is common lead
  1. Blower for The Demon V8
    By stevehuckss396 in forum I.C. Engines
    Last Post: 03-29-2020, 01:35 PM
  2. blower model
    By brokenrinker in forum Mechanical Calculations/Engineering Design
    Last Post: 11-03-2012, 04:52 PM
  3. 5HP 3PH motor + 2000CFM blower.
    By diyengineer in forum Maintenance DIY Discussion
    Last Post: 04-26-2011, 10:38 AM
  4. Vacuum or Blower
    By stickermanstl in forum Commercial CNC Wood Routers
    Last Post: 03-04-2010, 01:38 PM
  5. material removal / air blower help
    By DrStein99 in forum DIY CNC Router Table Machines
    Last Post: 10-21-2005, 01:49 PM
