586,106 active members*
3,157 visitors online*
Results 1 to 14 of 14
    Mar 2005
    816
    Measurement Macros
    Here's a interesting measurement Macro from my Lathe.
    I guess issued by G65 P9018 X xa;
    O9018
    #1=#4001
    G00 X[24-10.0];
    G31 X[#24+5.0];
    IF[ABS[#5061-#5081-#24]LT5.0]GOTO 9018;
    #3000=80(PS);
    N9018#4=BIN[BCD[#4120]AND255];
    G10P#4X[#5061-#24];
    G #1 M99;
    I thinking it could be made a little bit better becuase what it seems to do is some tolerance checking and X axes setting of the automatic tool offset.
    Sep 2011
    78
    aren't the macro's suplyed by tha probe manufacturer??
    Mar 2005
    816
    Yeah they are usually.
    There's a few of them in my lathe. They all seem to do slightly different things. I'm used to the measurement in the mill.
    My mill probe is a CAT40 renishaw MP3.
    This macro uses the G31, G10P plus a IF statement and variables. My others don't.
    May 2004
    97
    That doesn't match the format I've seen for Renishaw Lathe Macro 9018. Normally 9018 is a Z Axis measurement, but the format looks different.
    Mar 2005
    816
    Yeah, that's why I mentioned it.
    It's not a Renishaw macro.
    It just made me wonder. Theres a similar macro in the FANUC manual.
    Sep 2011
    78
    can't help you on this other than that i could suply the renishaw macro's that are in my lathe
    Aug 2011
    2517
    I'd be interested to see a lathe Z measurement macro if you have one?
    Sep 2011
    78
    gonne look into it.
    if i have em at home i'll post in a moment. if not gonne get them from work tomorrow.
    Sep 2011
    78
    as mentioned Z measurement macro including used submacro's.
    I 'm bit familliar with parametric programming but translation this to what it actually does is gonne take to much time for me.
    Might be easyer for you.
    Aug 2011
    2517
    ok thanks.
    do you have any info on what the various user-input local variables are used for? For example #3, #4, #9, #17, #21, #26 etc and several on the G65 lines such as G65 P9030 D[#26] V[#22] E[#3*#7] H[#11] M[#13]
    It appears #26 is the target Z point but even if the actual numbers are known a text explanation of the variable usage is needed otherwise it doesn't make much sense :-)
    Or maybe you have another program that sets all those numbers? I assume there is another program because local variables are cleared on power-off/reset so it would be dangerous to run that macro program without something that re-sets the local variables first.
    Mar 2005
    816
    Me too. I would like to learn this type of macro / variables usage. I've only recently started using the Renishaw MP3.
    There's supposed to be some sort of measures on my Mori SL lathe. No saved programs for this.
    I still have yet to implement measurement on the 10TF.
    Aug 2011
    2517
    on older Mori SL lathes there's no probing but there can be a setting arm. no macros are used though it's purely for setting tools.
    Sep 2011
    78
    Read all about it http://www.promoil.com/tools/renishaw/21.pdf.
    Myself, I only use diametrical meassuring once in a while on a lathe with loader system. but although is seems great its use is limmited.
    When using a inserts drill the disc that shoots out at the back of the product might break the probetip.
    Also you must be sure that u dont produce long "stringy" chips (not even once in a while) because these might twist and grab the probetip and break it.
    For cast iron matrials (with I almost never have) and other short chip matrial its a great tool letting you produce the whole loader table without making scrap parts once in a while.
    Mar 2005
    816
    I've only just started using the Mori SL3H in the last 6 months o I haven't gotten very deep into it.
    Well, the 0T / OT which has a A02B-0091 system also has measure too with the macros.
    I just touch off and use the calculated X and Z for finished parts.
    The 10TF I normally work on has macros similar to the 15T I investigated beforehand the build.
    I use pretty efficient chipbreakers so chiphandling is pretty neat. We don't use insert drills except in milling.
  1. How do I re-edit a measurement once I go to 3D???
    By BrassBuilder in forum Uncategorised CAD Discussion
    Last Post: 01-17-2014, 04:01 AM
  2. frequency measurement
    By pradeeptamangs in forum CNC Machine Related Electronics
    Last Post: 06-14-2013, 05:25 AM
  3. A measurement of backlash
    By dlaery in forum Taig Mills / Lathes
    Last Post: 04-19-2012, 12:33 AM
  4. 0.01 mm Tool Measurement
    By Leha_Blin in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-09-2009, 06:04 AM
