586,103 active members*
3,224 visitors online*
Results 1 to 11 of 11
    Oct 2011
    24
    Fanuc 0I-MC DPRNT
    Hello,
    I have a problem, i have two machines where i am using a touch probe to measure my machined parts and printing the variable to my memory card with the function "DPRNT" . Both controllers are Fanuc 0I-MD, i am trying to do the smae with the 0I-mc but no response.
    I can import and export files from the card but no response while using "DPRNT".
    Does anyone know if it is maybe a parameter that needs to bet set right .BTW i am using I/O 4 so that is not the problem.
    May 2004
    97
    Do you get no response or an alarm?
    Normally with the Flash Card there are 2 file types the POPEN can produce - 1st format is MCR_PRNT.TXT which will cannot be appended to or overwritten. You have to dump all the probing information out in a single POPEN / PCLOS.
    The 2nd format is PRNTxxx.DAT where xxx is an incremental number that increments with each subsequent POPEN.
    It is possible with a parameter to change the format on some more modern Fanuc controls.
    Oct 2011
    24
    I got no response at all no alarm and no message. If I put the I/O on a different Channel I get a alarm. There is no problem with format . Like I said two different machines with a newer model do print . I have a feeling that maybe the option is blocked or not installed correctly.
    May 2004
    97
    Have you tried RS232 output (change Data I/O channel to 0 or 1)?
    Interested to know if the problem is the Flash Card port or the DPRNT itself?
    What are you doing with the data - if it's Renishaw output I can help A LOT
    May 2004
    97
    I have seen in the OiMC parameter manual mention of parameter 0138, bit 7 (MDN) "The DNC operation function by a memory card is: 0 - Disabled; 1 - Enabled"
    Not sure if this is relevant as it seems to be more aimed at DNC but worth a look. Let me know if it does anything.
    Oct 2011
    24
    Quote Originally Posted by guypb View Post
    i haven't realy tried the RS232 because i dont know how LOL.and yes i am using the data for probing, don't use the probe of renishaw and i use solidcam to make my G-codes .
    Oct 2011
    24
    I will have a look tomorow morning if that will help.but i suppose that is is correct because i can use my flash card for transferring programs.
    May 2004
    97
    Quote Originally Posted by rwazana View Post
    happy to show you what's possible with RS232 - interested to know how your programming probing with SolidCAM. PM me and maybe we can help each other.
    May 2004
    97
    Are you sure that MCR_PRNT.txt is not being created on the PCMCIA card? What file format are you getting on the OiMD?
    Oct 2011
    24
    yeah i'm sure i don't have the file on my PCMCIA card .on the 0iMD i get a PRNTxxx.DAT file.
    Oct 2011
    24
    I have checked this morning about the parameter 0138 and it is enabled on the 0iMC and 0iMD.
  1. DPRNT
    By TiagoISICOM in forum Fanuc
    Last Post: 04-05-2013, 12:32 PM
  2. DPRNT help
    By DerbyCountyFan in forum Haas Mills
    Last Post: 02-11-2011, 01:56 AM
  3. Replies: 17
    Last Post: 02-22-2010, 03:40 AM
  4. Do you use DPRNT?
    By gar in forum Haas Mills
    Last Post: 10-23-2007, 04:02 PM
  5. Macro DPRNT please help
    By MarkoH in forum G-Code Programing
    Last Post: 06-19-2006, 06:37 PM
