586,061 active members*
4,619 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > PARITY ERROR ONLY WHEN SERVO DRIVES ARE ON
    Jun 2013
    4
    Hi, I have recently bought a hurco hawk 5m with ultimax3 control, i'm having problems with a parity error which only happens when the servo drives are switched on, When the power to the drives is off the program loads fully into the memory fine, But with the power on i get this parity error sometimes at the beginning of loading, sometimes in the middle of loading but it always stop at some point with this parity error. I have tried differtent setting for the baud rate, character length, stop bit, parity but still no difference. The setting that seem to work best are
    baud rate:9600
    stop bit:1
    character length:7
    protocal:xon/xoff software
    parity:even
    sorce/dest:memory
    The software on the pc is hsm edit and the dnc setup has \17 as xon character and \19 as xoff character(not sure if this is correct). The cable I'm using is a null 9pin D type rs232. The reason I need the servo power on is to drip feed a large program. Any suggestions would be appreciated. Many thanks.
    Jun 2008
    1104
    Send the program to a disk file instead of memory and run it from there.
  1. Fanuc error 998 ROM Parity Error ???
    By ED209 in forum Fanuc
    Last Post: 02-07-2022, 10:02 AM
  2. PARITY ERROR ONLY WHEN SERVO DRIVES ARE ON
    By casecom in forum HURCO
    Last Post: 11-07-2013, 01:36 PM
  3. Replies: 0
    Last Post: 11-26-2012, 09:03 PM
  4. TH parity error?
    By keystone76 in forum Controller & Computer Solutions
    Last Post: 06-27-2012, 09:18 PM
  5. Ram Parity Error
    By rags in forum Fanuc
    Last Post: 12-19-2008, 09:03 PM
