586,416 active members*
3,180 visitors online*
    Nov 2011
    8
    Squaring the Gantry to the X-axis
    Hello
    I have a CRP4848 up and running for a while now... I recently had to move the whole machine from one point to another in my shop. In the process, it seems that the gantry is slightly out of square with the X-axis. I was wondering if folks have any BKMs to share regarding how they squared up these two axes...
    I use two homing switches on each x-axis that i can reposition to bring the gantry back in, but its not a very elegant procedure... more like trial and error.
    Anyone have any procedures they'd like to share?
    Andy
    Mar 2011
    584
    Drill or mark 4 holes in the corners of the machine using your router and measure diagnol just like squaring a deck. Once you get it close that way then do the same thing in a smaller square like 3" so you can measure them with a caliper and fine tune it.
  1. Need help with FLA-100 Gantry y-axis
    By sports.racer in forum DIY CNC Router Table Machines
    Last Post: 07-25-2012, 05:47 AM
  2. Squaring a gantry - without a square?
    By Instance in forum DIY CNC Router Table Machines
    Last Post: 01-20-2011, 09:37 AM
  3. Squaring the gantry
    By bradbergemann in forum Excitech routers
    Last Post: 01-07-2010, 02:31 PM
  4. Squaring x an y axis in Mach 3
    By garychief in forum Mach Software (ArtSoft software)
    Last Post: 05-31-2009, 02:16 PM
  5. Squaring your Gantry, 1530 and similar.
    By Big S in forum Excitech routers
    Last Post: 04-15-2009, 10:23 AM
