I work in a research lab, and we have been milling tissue samples imbedded in plastic. We have been using a Taig CNC mill as a proof of concept device, but we would like to build our own machine. The process goes like this: Place sample in vise, take a .0003 cut across sample with a 1.500 shell mill, stop spindle to lessen vibration, move over to microscope to image, turn on spindle, and repeat. This can take over 24 hours, depending on sample size. In the end, the images are stitched together to create a 3D image of the sample
What I need help with is what type of bearings to use for our spindle? We would like to run the spindle at least 10,000 rpm, and for long periods of time. There are no real cutting forces, and the greatest load I can see the spindle taking, is the torque it would see getting it up to speed.
Any help pointing me to the right type of bearing to use would be appreciated. I've tried talking to a few custom spindle manufacturers, but they seem to want me to supply the designs, not them. I tried looking at the various bearing manufacture's web sites, but I can't seem to find the information I'm looking for and get bogged down, start feeling dumb, and get the urge to nap.
The other issue is how to drive the spindle. We have been thinking that a belt drive would be best to lessen vibrations from the motor being transferred to the spindle, is this sound thinking? Also, what is the maximum speed a small belt drive can run at? Or should we be using a direct drive motor?
In the end, I was hoping that a simple aluminum block, with two of the right size/spec'd ball bearings, running by belt to a motor, would be good enough to get the job done.
Thanks for your help!
