586,103 active members*
3,245 visitors online*
IndustryArena Forum > CAM Software > Mastercam > custom drill cycle for multiple feed rates?
    Dec 2011
    7
    All,
    I'm working on changing up a drill cycle for tubing. I'd like a G81 cycle that drills through one side of the part, then feeds/rapids through the middle of the part which is open, then feed through the far side of the part. Is anything like this possible?
    Apr 2006
    3206
    Subroutine
    Jul 2013
    6
    There is . It is called a web cycle. . It is designed to do what you are asking for. If my memory serves me correctly it is a g85. Let me check it out .
    Dec 2008
    3109
    Quote Originally Posted by chub View Post
    All,
    The only option is to remove the cycle completely, and manually program the drilling path longhand
    - use "drill point" ( to get the required tool into the spindle), and then insert the follow code into a "Manual Input" ( you may have to do a minor edit in the NC code )
    ie
    G0 Z.1
    G1 Z-.2 F3. ( 1st wall)
    G1 Z-.5 F10.( fast feed thru middle )
    G1 Z-.7 F.3 ( other wall)
    G1 Z.1 F10. ( faster feed to allow swarf to be drawn off the tool )
    G0 Z.5
  1. Adding Custom Drill Cycle to MCX6
    By txcncman in forum Mastercam
    Last Post: 01-11-2013, 01:57 AM
  2. Feed rates?
    By Rainman229 in forum G-Code Programing
    Last Post: 02-23-2007, 06:47 PM
  3. Feed Rates
    By rcheli in forum Benchtop Machines
    Last Post: 12-28-2005, 05:34 PM
  4. Rpm and Feed Rates
    By Xeno in forum Uncategorised CAM Discussion
    Last Post: 02-23-2004, 11:06 PM
