586,096 active members*
3,667 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Possible to write variables to a program?
    36
    Question Possible to write variables to a program?
    Is it possible to have the program write the contents of a variable into a program on a Fanuc control (16i, 18i)
    I have a probing program that takes some points on the casting and then calculates all the work co-ordinates for all the B-axis rotations. There is one value that is measured, stored in variable #700 that needs to be logged for every part. This is currently done by hand. What I would like to do is have the program dump the variable into a file or program in the machine and just copy the file/program every week. we don't have a DNC system so it needs to be store in the machine until I can remove it with the memory card.
    I know on a Makino Pro3 control, the tool files (all the tool data) can be output into a program on the machine with an M code. But that data is in the custom pages and a pro3 is a different animal then a normal fanuc 16 control.
    any thoughts, ideas are greatly appreciated
    dan
    Aug 2006
    12
    You should be able to store the measurements to tool offsets or common variables, but I dont know how you get them off of the control without backing the whole thing up. There is no way to change strings in a program through another one.
    With Okuma there is a way to have it print (output) to an external device, i would assume fanuc would have something similar. I will root around in my fanuc manuals tomorrow if i remember.
    Aug 2006
    12
    ah cool, dont even have to root through those darn fanuc books!
    http://www.cnczone.com/forums/showthread.php?t=9816
