586,042 active members*
3,743 visitors online*
Results 1 to 9 of 9
    Jun 2006
    4
    RFQ - 29 part Brass or Aluminum
    Hi All,
    I have a 29 part device specified as Solidworks files. The assembled device would be the M-94 cipher device used around the first World War. (See M-94 Cipher Device for a detailed look).
    I'd like two quotes, one for brass, the other for an appropriate aluminum that can be handled by hand (and it's OK if you just quote one only).
    Initial runs are likely to be small and I would reorder as needed.
    I'm not a machinist, so I'll appologize in advance if I don't get the technical terms right.
    pm/email me for the zip file. It's 22MB, so larger than the allowed size for this forum.
    -Giff
    Apr 2013
    99
    You do know those were die cast probably pot metal not aluminum.
    6061 would be to soft.
    The engraving will require a 4 axis machine.
    very expensive for a small number.
    Jun 2006
    4
    I figured they were casted, would there be a different group I should go to for making these?
    Apr 2013
    99
    not really just depends on what you want, the range is functional easy to distinguish, from original to near perfect copies.
    different skill sets and equipment needed for the different products, and different price as well
    Nov 2012
    55
    I tried to PM you but it said you were not accepting PMs. Can you email me the files at [email protected]? Thanks!
    Jun 2006
    4
    For ATWdwilliams and CNCPro26, I've got emails on their way to you. Thanks much.
    Hello,
    I would like to quote you on this . Could you send me an email to [email protected].
    Thank you.
    Jun 2006
    4
    Email on the way.
    Nov 2005
    218
    info (at) tinkerhaus (dot) com please send the file.
  1. rfq for brass part
    By Runner4404spd in forum North America RFQ's
    Last Post: 08-30-2012, 08:48 AM
  2. RFI - CNC tapping small holes in brass & aluminum
    By mhackney in forum Benchtop Machines
    Last Post: 01-14-2011, 08:57 PM
  3. aluminum and brass
    By azureskys in forum Casting Metals
    Last Post: 03-13-2010, 06:23 PM
  4. Small brass part (sketch attached)
    By marvfrankel in forum Employment Opportunity
    Last Post: 06-04-2008, 02:44 AM
