586,075 active members*
4,515 visitors online*
Results 1 to 8 of 8
    May 2011
    15
    50 w Laser with z axis table what distance
    I have just bought a 50 Chinese laser with moveable table z axis, how far should nozzle be to workpiece
    Jan 2008
    940
    What lens do you have? you should have gotten a focal gauge
    wklaserliu Guest
    Quote Originally Posted by justy22 View Post
    Hi your 50w laser machine i think is DESK top one , normally desk top one the Z up&down table distance is about 20cm ,this s also not same according to what model &type of machine you bought.
    Quiven
    g.weike laser, manufactuer /supplier of laser engraving machine in Jinan China
    [email protected]
    [email protected]
    skype: wkquiven Click image for larger version.
    Nov 2009
    314
    Dear ,
    Do you use auto focus or a normal laser head ?
    If you use a normal laser head that each time you can find the focus length by the focus block ,which was packed with the machine. Just put the block on the material and below the laser head . The block will help to find the distance .
    If you use a autofocus laser head , there must be a button to make this function take effect . Only need you to put the material on the table ,make sure laser head is above the material , then start the autofocus function . It will find the focus length by itself .
    Nor matter what methods , you can get a very very small dot on the material , that proves correct distance . Or you may try this just find the smallest dot by firing laser . Like pictures do !
    Attachment 208254
    Attachment 208256
    Attachment 208258
    Attachment 208252
    Best regards,
    Mary Lee
    XYZ Machinery
    May 2011
    15
    The seller said its 40mm from the lens which works out 11mm from nozzle but trying to engrave rubber at this distance is no good machine engraves much better when nozzle is about 20-25mm away from workpiece, can anybody explain this is the machine I bought here NEW CO2 LASER ENGRAVING MACHINE ENGRAVER CUTTER AUXILIARY ROTARY DEVICE 50W k1 | eBay
    Jan 2008
    940
    That unit looks like one I checked out and it had a 50mm focal length it had a 54mm gauge that looked like a 7 you put it on the material and then you adjust the tube so the little nub is on the top of the lens holder.
    May 2011
    15
    Quote Originally Posted by fixtureman1 View Post
    50mm sounds more like it but I would like to know for deffo, the 7 gauge may have came with it and I may have put it in bucket by mistake, I love the machine I used to have the cheaper 40 watt one, I paid £1695 all in but noticed he has put price up to £2695, I use it for making rubber stamps but would like to start learning other things to do with it
    Jan 2008
    940
    Here is a dfx of one that I made for my laser
  1. Z axis travel distance?
    By NogginBoink in forum Open Source CNC Machine Designs
    Last Post: 11-11-2013, 05:38 AM
  2. Table Slot Center -to Center distance
    By bostosh in forum Haas Mills
    Last Post: 10-25-2010, 03:41 PM
  3. Profiling axis distance corrections
    By harryn in forum Mach Mill
    Last Post: 10-12-2010, 06:32 AM
  4. Z Axis Travel Distance
    By WarrenW in forum DIY CNC Router Table Machines
    Last Post: 06-01-2010, 12:57 AM
  5. distance z axis can travel
    By mostlund in forum DIY CNC Router Table Machines
    Last Post: 12-15-2008, 05:04 AM
