Well I got it working
Well I tried a few different wiring option with no luck. Then I tried wiring a separate +5V wire to the En pin on the BOB and also to the +5V in on the BOB and what do you know I got +5V out and the router works for the most part. Still think I have a few issues in my software to sort out.
Had all three axis running over 300 IPM (very conservative). I actually tried the Y axis at 500 ipm and did not get any complaints from the machine. I do not have the Porter Cable 7518 router mounted to the Z axis right now, so I am sure that when I add that weight it will slow it down some.
Thanks to all that have helped with particular thanks going to Mariss of Gecko Drive and Art from CNC4PC. You both have done a wonderful job supporting you products and working with each other to help solve this problem. Hopefully we can consider it over with.
Thanks again
Dan
Check out what I am working on at www.routerbitz.com!
