I have a 1987 Bridgeport Interact 1 MkII with a Heidenhain 151 controller. The machine has been running well until it slowly would indicate that the machine has hit the limit switch when it was not near the switch. The envelope that the machine could run in without showing the switch warning grew smaller through time. The last time it was run, it booted up fine, homed as usual, but as soon as I tried to jog it off the limits, it showed the limit switch warning and would not go farther. I am able to jog all axis back and forth about 1/4", but that is all. I I jog any of the axis, it shows up as the limit switch that was hit. I have driven the y axis off manually and it moved back to the Y limit with the jog control, but would not reverse.
The machine will boot up, but will not home. I can manually move the axis the 1/4" it allows and it will pass over home in all axis. The control then displays the manual mode, as usual. I can not move it farther than about 1/4".
I have checked voltage and continuity through all of the limit switches, check lube oil level and checked voltage and they are OK. All of the ready LEDS on the drive cards are lit, and as I mentioned I can drive all axis a very small amount with the jog control. I have also checked the 24V controller voltage. The controller was checked and updated by Heidenhain a year and one half ago. I can not drive the table off the limit switches with the power enable button depressed.
Any ideas of where else to check?
Thank you very much for your help.
