586,105 active members*
3,343 visitors online*
Results 1 to 13 of 13
    Oct 2012
    29
    Question What 5-Axis mill
    Looking for A 5-Axis mill.
    And the contenders are:
    Hermle C400
    Doosan VC630-5ax
    DMG DMU 75 Monoblock
    Hedelius RS505
    Any suggestion and things you say to look for?
    Any input is appreciated!
    Thanks!
    Nov 2012
    70
    Looking for real high quality I would definitely go for the Hermle
    Doosan probably also OK relative to the smaller investment
    DMG you pay a lot just for a name
    Hedelius probably cheapest both price tag and contruction
    Oct 2012
    29
    Quote Originally Posted by The Swede View Post
    Yeah, Hermle as a manufacturer is probably the top brand, but looking for spindle spec's(Nm, kW), etc they are lower, for a higher price it doesn't seem the perfect choice.
    You would rate Hedelius lowest of all?
    DMU's used to be at the top, are the really that bad nowadays?
    Nov 2012
    70
    Depends what you need. 18k rpm and higher Hermle is a good choice. If 12k rpm with higher torque is prefered Doosan may be a better choice
    I rate Hedelius lowest due to the welded construction filled with nothing. Know users in Sweden having problem with vibrations on larger models Hedelius because of this. Only plus as I see it is the low price and closeness to the manufacturer for you
    I don´t say DMG is a bad machine, but I don´t think it´s as good as the price tag reflects
    Is Heidenhain control a demand ?
    May 2013
    44
    FWIW- I just bought a Matsuura MX 520. It seems to be a lot of machine for the money.
    Oct 2012
    29
    Thanks for the input!
    Didn't know of the hedelius issue! Good to know!
    No not at all!
    All is programmed by CAM!
    So would just need a short block processing time, Which the Fanuc 31i 5 axis has, aswell as the Heidenhain 530.
    Nov 2012
    70
    Then I think you should take a closer look at Hurco model VTXU (only this model built as 5-axis from beginning, not the smaller VMXU models)
    12,5 ton cast iron construction machine.12k rpm spindle with 237 Nm. Simultaneous 5-axis. And a very fast control for 3D-machining. Also no problem at all to use ISO programming with CAM-system (some people still think Hurco is only for conversational programming)
    Oct 2012
    29
    Did have a look at the Hurco!
    Only has a very high price for a machine with such a low accuracy in XYZ, the axis you will still use the most!
    Nov 2012
    70
    I believe Hurco not promising a high accuracy in the proposals partly has to do with being a US company (heavenly country for the lawyers). There may be harsh instructions from US never to promise anything in writing that you may be even close to get in trouble for later
    However if longtime high accurary is a main concern I would definitely vote for Hermle. Or maybe Matsuura as suggested or Makino or Mori Seiki (not DMG) but they all are probably more expensive than Hermle
    Oct 2012
    29
    Hurco do promiss high accuracy on the 4th and 5th axis that is why it concerns me.
    With the new Mori Seiki it's hard to find which are from the collaboration and which are from Mori only. Here they are now also supplied by DMG.
    Makino and Matsuura didn't ask for a qoute, guessed it would be Mazak range. Too high what we use it for.
    Dec 2013
    34
    Hermle by far is the best choice. Very solid one piece casting for rigidity and vibration absorption. They have a very solid spindle design with safety crash prevention in the spindle so you only have to replace certain cheaper parts in event of a crash instead of a spindle which could cost as must as $30k. Crashes are more frequent on 5 axis usually due to a programming error.
    All guideways are designed outside of machining area. Oversized gearing on rotary table tandem drives give it very right rigidity. Dmg only has one point of contact for rotary table I contact.
    Hermle also has very reliable customer service and support. Good luck!
    Russ
    Oct 2012
    29
    Thanks guys!
    Must say, Hedelius does have some big advantages to a hermle though. They have the formingstar, good for 3D finishing, and high speed roughing. They have torque motors in the 4th and 5th axis. Something that in a hermle would cost you 20k.
    We have seen the Hedelius, Doosan and Hermle in action now. Doosan seems quite rigid, but its insanely big. We do not have that much space available. Hedelius RS505 cut's with 50mm mill in steel, like it's only cutting air. So Nothing wrong with the rigidity there either.
    The Hermle is quite pricy and doesn't have that much on a Hedelius.
    Dec 2013
    34
    Hermle is def the most expensive of the choice. But in the long run it is the more overbuilt machine. (Just look at the casting). I still feel in the long run even though it might cost a little more that it would last longer.
    Also how is their service? I know hermle's is very good here in the US. Very important at the end of the day
    Russ
  1. 4-axis mill post and a-axis datum setting
    By inflateable in forum EdgeCam
    Last Post: 02-09-2011, 09:35 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  3. feedback on a Z axis kit for a knee mill and mill drill
    By extsuba in forum Vertical Mill, Lathe Project Log
    Last Post: 04-01-2009, 12:06 AM
  4. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
