360 brass being turned with high speed steel insert. Positive rake and no chipbreaker. No fluid, not an option. Tried 300-1000 RPM .002-.008 depth manually and with .005-.015 feed. This thing keeps grabbing the work. The workpiece is 6 inch long 2" diameter hanging out from a 6 jaw chuck about 4" probably with <.005 TIR at the end. The lathe is too small to chuck the work closer but if the runout is the problem then I could try to turn between centers but then I'd have to drill this stuff. Any suggestions?
