Hi all,
I need help to determine whether a stepper motor will be suitable for the following application:-
4-6Ib (2-3Kg) mass is required to be moved 2-3in (50-75mm) at a frequency of 0-175 cycles per minute. Positioning accuracy is not critical although expected to stay within a approx 0.25in during anyone use. The device will be operated at upto 175 oscilaltions per minute for 15-30 minutes continuosly.
I have no idea whether a stepper motor can handle the kinetic energy created by moving this amount of mass at these speeds? If one can then what sort of voltage/currents will I be expecting to handle? (any reccomendations on motor supplier would be a bonus )
Once I can get a pointer in the right direction in regards to the base motor type and size I can handle the remainder of the project (control system, software etc).
Regards
