586,100 active members*
3,089 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > disable the scale in fanuc OGC System
    Nov 2013
    Post disable the scale in fanuc OGC System
    I have Fanuc OGC System,in this X-axis has scale for feed back,due to some reason i need to deactivate it, Pl help me what are those parameter to be adjust to disable the scale.
    thanks in advance
    regards
    ram
    Jan 2011
    350
    Well if it's like 0GSC system then it would be 0037#0 for X axis scale deactivation set it to 0. Also swap your X-axis scale and motor coder cables on your servo drive.
    Cheers.
    Nov 2013
    thanks i have deactivated by using that parameter
    Regards
    Ram
  1. How to disable the Windows on Fanuc 160is
    By Namnp2007 in forum Fanuc
    Last Post: 12-01-2022, 12:17 PM
  2. Axis disable in fanuc 31i- madel A5
    By srimurthyb in forum Fanuc
    Last Post: 10-31-2012, 09:33 AM
  3. Replies: 0
    Last Post: 10-10-2012, 12:04 AM
  4. Fanuc OTT C Axis Disable - URGENT HELP PLEASE
    By BryCAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2011, 06:15 PM
  5. Fanuc 16i-M 4th axis disable
    By MDR32 in forum Fanuc
    Last Post: 07-23-2010, 01:07 PM
