586,060 active members*
3,962 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma es l6 copy multiple program from machine to floppy
    Jun 2013
    5
    Okay you guys so here's my problem, I am trying to copy multiple program at once through the ms-dos but I only know how to do it one at a time, is it possible to copy multiple programs at once?
    What I am doing
    Edit:ms dos : program out : select program : write
    Any help would be amazing thanks!!!
    Apr 2009
    1262
    Instead of selecting program, use wildcard *.* for filename to get all programs.
    Remember DOS disks will want 8 character or less file names while the Okuma can handle 16 so so name changes may be needed and the wildcard may not work for all programs if this is the case. This can be accomplished as you output by adding a comma and the new filename as you output. Ex: output PARTABC123.MIN,PARTABC1.MIN WRITE
    You can also verify what you want to copy by adding ;V to the end of the command. This will ask to to confirm Y/N each program as it outputs. This is an easy way to skip the output of a program with a long filename while getting all with short enough names.
    Best regards,
  1. OKUMA OSP Floppy Simulator
    By kurmay in forum Okuma
    Last Post: 03-10-2024, 10:13 AM
  2. Okuma floppy to usb conversion
    By Edster in forum Okuma
    Last Post: 07-26-2023, 12:29 PM
  3. OKUMA OSP Floppy Reader
    By erdemkaraman in forum Okuma
    Last Post: 08-10-2011, 07:39 AM
  4. okuma floppy needed
    By cinci5 in forum Okuma
    Last Post: 03-06-2009, 02:58 AM
  5. copy and rotate, help (okuma)
    By zooloader in forum G-Code Programing
    Last Post: 06-27-2005, 01:01 AM
