586,102 active members*
2,601 visitors online*
    Jun 2008
    47
    Craftex Mini lathe Stalling
    Hi guys, I hope someone can offer me some advice.
    Does anyone know how to adjust these 3 screws to get the lathe to have more power at low speed so it doesn't keep stalling? I have tried turning them C.W. and C.C.W. 1-2 turns and it doesn't seem to have any effect. My first lathe was faulty and would take a tremendous load without stalling, so much so that it burned out the motor, so I believe it is possible to get at least some extra torque at low speed by adjusting these three screws, I just don't know which one(s), which way and how much.
    Also, the lathe takes a short period of time to get up to speed in high gear, it didn't do that before. I have had the lathe for about 4 years.
    Thank you for taking the time to read this.
    Colin
    Apr 2003
    131
    Colin:
    Don't bother. About a decade ago I replaced the mini-lathe drive with this one from McMaster: McMaster-Carr
    $143, US made excellence and zero issues. I had gone through several of the OEM drives at that point, they're simply under-engineered.
    There's a detailed setup guide that comes with the McMaster drive (it's made by Leeson - in Grafton WI) for how to set the pots - there are six of them for min speed, max speed, accel, decel, torque, and regulation (IR comp).
    Works like a dream. Don't worry that it's "non-reversing", use a DPDT switch after the drive to switch the armature polarity on the motor (same as with the OEM drive).
    Hope this helps.
    -Dave Kowalczyk
    Author of TurboCNC --> http://www.dakeng.com
    Jun 2008
    47
    Thanks Dave, for answering my post--I might give that a try.
  1. Craftex Mini lathe Stalling
    By basalt in forum Mini Lathe
    Last Post: 11-16-2013, 06:44 PM
  2. Own Craftex Mini Mill?
    By ericdwilso in forum Benchtop Machines
    Last Post: 08-01-2009, 02:20 AM
  3. craftex mini mill
    By dertsap in forum Benchtop Machines
    Last Post: 05-28-2009, 04:36 AM
  4. craftex 13 x 24 metal lathe
    By murph1411 in forum Mini Lathe
    Last Post: 03-15-2009, 11:28 PM
  5. New cnc on Craftex B222L lathe
    By HeinrichII in forum Hobbycnc (Products)
    Last Post: 05-04-2008, 12:38 AM
