I had purchased a mill w/ fanuc 10m controls. Was working when purchased. During freight, one of the connectors for the servo motors broke and pulled the harness out. Repaired that. When machine is turned on, everything seems ok. Table motors work and I can control them from the panel just fine. I cannot get it to turn on the spindle motor. I can push the contactor in the relay and make the motor work, but I cannot figure out how to turn the motor on manually. I don't need the cnc running as I just needed to use the readout as a dro and do some manual work. Anyone know how to just turn the motor on manually?
