So I looked over the machine, everything is tight.
I used the MPG mode to jog 1" at at time and I was 0.985" in the X and something very similar on the Y. So I ran the Mach 3 Calibration again and I asked for 1" movements.
I dialed it to 1.002" +/- 0.001" Which is pretty good.
I noticed that mach 3 will not adjust the slave motor accordingly to its master, so I made the change manually.
Can you guys confirm this is correct ?
Everything seems to work well close to the origin.
I looked over my g-code in notepad, and I looks good, I even change it to stop and end at the location I tell it to go to.
I also ran two small simple programs (cut a 2"x2" square) and move to a specific location and it is all working well.
I am going to run a larger program in a minute just to make sure that it comes back to 0,0
I don't mind running a little slow if that mean accuracy. My motor settings after the mach 3 calibration os
X = 2043.526 / accel 29.79
y = 2064.314667 / aceel 29.49
