586,072 active members*
4,472 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > wiring up g0704s estop to mach
Results 1 to 9 of 9
    Oct 2009
    446
    He fellows . I need some help have any of you wired up the existing estop on you BF20/G0704 to mach 3 ? Or does any one know how to.
    It would save me allot of trouble if this was possible.
    Aug 2004
    3215
    It depends on what controller system you are using, geckos, geckos with a BOB (Breakout Board), keeling with BOB etc. they should have a downloadable schematic for you BOB for the pin outs. Even a smooth stepper is a little different.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
    Oct 2009
    446
    Joe thanks for the replies .
    There more the 2 ways to wire a estop up? N/O & N/C ?
    Well my BOB (c35) you either touch 2 pins together to trigger the estop or they are separated. I was curious if any one used one of those 2 combination and wired it to the G0704 Estop that came on there mill .
    24221
    E-stop is always N.C. fail safe and should be a hard wired circuit, and not depending on some software based system, although any can be included in the primary E-stop circuit.
    Al.
    Albert E.
    Oct 2009
    446
    Thats what im trying to do Al . Wire machs estop in with stepper motor drivers and spindle. So I can shut down everything at once.
    I think I got it I have a second Estop here Im going to use.
    Thank
    Nov 2009
    4415
    Are you referring to the spindle control safety switch? I believe this is high voltage, if there was an extra set of contacts on that switch maybe.
    Oct 2009
    446
    Quote Originally Posted by Fastest1 View Post
    It is high voltage . Im not the best with electronics like allot of the members on the board. I wired a second estop on the top of the control box . It has 2 separate connections . It looks exactly like this one.
    It shuts the power down on the spindle before it gets to the board. Then on thge other side I have a estop for mach. I have to figure out how to shut the drivers down I dont like depending on the software to stop everything but my spindle.
    CNC Emergency Stop Mushroom Pushbutton Switch 10A | eBay
    Nov 2009
    4415
    Look into using a contactor. A contactor when connected correctly will shut down all electrical power to the machine. Understood on the electrical understanding. That is why I am here all of the time, trying to learn about it myself. I do make little gains occasionally in my understanding.
    A lazy man does it twice.
    Nov 2009
    4415
    Another option would be to control your spindle power with a relay controlled by Mach instead of the switch. Though I like a safer set up this would work. When you tripped the EStop , Mach would kill the power to the relay.
    The contactor is still the safest way and could be connected to trip Mach when an EStop was tripped. Another good safety feature to implement is the charge pump. This will not allow the controller to do anything unless the computer is connected and Mach is running.
  1. HELP, mach throws up random ESTOP mid program. Gecko G540
    By dougie329 in forum Mach Software (ArtSoft software)
    Last Post: 12-04-2011, 07:35 PM
  2. Need help with Mach Motion wiring, V2XT
    By Lasershop in forum Bridgeport / Hardinge Mills
    Last Post: 12-06-2009, 06:42 PM
  3. need estop wiring diagram and how to for limit switches
    By eloid in forum CNC Wood Router Project Log
    Last Post: 11-06-2007, 03:55 AM
  4. Mach 2 Estop problem
    By dentman in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2005, 01:32 AM
