586,111 active members*
3,260 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > 770 spindle won't work in manual mode?
Results 1 to 8 of 8
    Jun 2012
    59
    I don't switch to manual very often but I've never had a problem.
    I had a quick straight line to cut last night but couldn't get the spindle to turn on. I rebooted everything twice last night and started up again this morning.
    I'm I missing something? Something in Mach 3 that needs set?
    Jun 2006
    3063
    Maybe a loose wire on the manual/off/auto spindle switch?
    Jun 2012
    59
    Thanks, I checked the wires first thing and they all see fine.
    Jan 2007
    869
    Power off the mill and unplug it and maybe check the switch to see if it went to switch heaven? Maybe the switch broke.
    You should be able to use a multimeter to check if the switch is working.
    Wade
    Feb 2006
    1072
    F5 on the keyboard toggles the spindle on and off. I don't even have a manual switch any more so I always use F5 for "manual" spindle control.
    [ctrl-c] toggles the coolant pump, by the way.
    Randy
    Jun 2006
    2512
    The spindle should start in manual without the computer even being turned on, let alone Mach3 running. As suggested get a multimeter and start checking.
    Phil
    Mar 2009
    1863
    When I want to do manual work, I'll turn the spindle on in MDI then I can get the RPM I want.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Jun 2012
    59
    Thanks for the replys. I got really busy with Christmas orders. The machine is running in auto mode and I'm not going to rock the boat before Christmas. I'll play with your suggestions as soon as I'm caught up and have some time.
  1. how to get out of manual guide mode?
    By nabil_elbadri in forum Fanuc
    Last Post: 09-11-2012, 08:49 AM
  2. Replies: 6
    Last Post: 06-22-2011, 08:30 PM
  3. dro in manual mode...
    By triberman in forum Mach Software (ArtSoft software)
    Last Post: 03-02-2011, 08:24 PM
  4. Spindle Manual Mode
    By Mechamatic in forum Tormach Personal CNC Mill
    Last Post: 09-18-2008, 06:52 PM
  5. How to use my custom CNC mill in manual mode?
    By Spinnetti in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-23-2008, 01:37 PM
