586,119 active members*
3,325 visitors online*
Results 1 to 3 of 3
    Nov 2013
    GROSS POSITIONING ERROR S B Alarm
    Guys
    have a problem on a Bridgeport VMC 760 milling machine,keep getting the alarm GROSS POSITIONING ERROR S B when try to run the spindle or do a tool change,
    Its a Heidenhain control with seimens drives and motors
    any help appreceiated
    Cheers
    Taza
    Dec 2011
    99
    GROSS POSITIOINING ERROR <AXIS> B: The nominal voltage calculated by the control has reached its limit of ± 10 V (only with feed precontrol).
    When this error message is generated, the error may be located in any element of the closed loop. e.g.
    - Control error (e.g. CLP board)
    - Excessive offset voltage at the servo amplifier
    - Monitoring function of the servo amplifier has responded (e.g. power monitoring)
    - Servo amplifier defective
    - Motor, tachometer, encoder or cables defective
    - Mechanical defect (bearings, spindle, guides)
    - Excessive mechanical forces on a drive
    Apr 2006
    23
    Re: GROSS POSITIONING ERROR S B Alarm
    Did anyone get to the bottom of this one?
    I have the same problem on my 760. When you start the spindle it goes solid but will not rotate.
    I get the error only on the first tool change attempt then no errors on the screen or the drive amp or power supply.
    Thanks.
  1. Heidenhain Gross Positioning Error D on startup
    By iowa_jim in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-20-2012, 09:02 PM
  2. Bridgeport Gross positioning error
    By Ogre4x4 in forum Bridgeport / Hardinge Mills
    Last Post: 02-26-2011, 11:45 PM
  3. Gross Positioning Error
    By Shanghyd in forum Bridgeport / Hardinge Mills
    Last Post: 01-21-2010, 02:33 PM
  4. Bridgeport Interact 4-Gross Positioning Error
    By foolmaker in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2009, 10:13 PM
  5. HELP! Gross positioning error
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 04:11 PM
