586,115 active members*
3,458 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Power Up Issues with Sabre 750
    Sep 2005
    45
    So my Sabre 750 with A2100 controller started doing something new today. When I first power it up, it goes through it's entire boot cycle just like it is supposed to do. But when it comes to the "Machine Power Required" screen, it will not power up the system unless you continuously hold the green button. It powers up just like it is supposed to, as long as you hold the button. But as soon as you let go, it powers back down. It does not shut down, the system remains booted, and you can once again power it up by holding the button. But as soon as you let go, it loses power again.
    I tried shutting it down and recycling, but no change. I can't see that this is a switch problem, because the switch functions properly to boot up the machine. I also get no error codes, it just turns itself off. So my first thought is that maybe some relay has gone bad? Any ideas?
    Oct 2009
    34
    Dear Sir
    Please turn off the machine and turn ON again.
    Them you must check the diagnostic screen and look at if everything pass.
    Or you can go to the program were software and check if the input is present or not
  1. Power-up Problems with Sabre 750
    By flyinphill in forum Cincinnati CNC
    Last Post: 11-25-2019, 08:51 PM
  2. Need Help BP Boss Power Issues
    By markhas in forum Bridgeport / Hardinge Mills
    Last Post: 09-17-2012, 07:11 PM
  3. SABRE 1250 bad power supply
    By jaredsparks in forum Cincinnati CNC
    Last Post: 02-26-2012, 01:48 AM
  4. Having issues with my TTS & Power Drawbar
    By mooreaa in forum Tormach Personal CNC Mill
    Last Post: 12-04-2011, 03:00 AM
  5. 1989 Sabre 750 Fanuc OM Power requirements
    By laka in forum Cincinnati CNC
    Last Post: 09-25-2011, 02:49 AM
