So my Sabre 750 with A2100 controller started doing something new today. When I first power it up, it goes through it's entire boot cycle just like it is supposed to do. But when it comes to the "Machine Power Required" screen, it will not power up the system unless you continuously hold the green button. It powers up just like it is supposed to, as long as you hold the button. But as soon as you let go, it powers back down. It does not shut down, the system remains booted, and you can once again power it up by holding the button. But as soon as you let go, it loses power again.
I tried shutting it down and recycling, but no change. I can't see that this is a switch problem, because the switch functions properly to boot up the machine. I also get no error codes, it just turns itself off. So my first thought is that maybe some relay has gone bad? Any ideas?
