586,069 active members*
3,946 visitors online*
    Apr 2009
    32
    Citizen L20 tripping breaker
    Hi there,
    Our second Citizen L20 showed up today. Hooked it up to the same 208 3 ph power that our other machine was running on hours before. When I flip the 30A breaker on the new machine it trips. Resetting the buttons on the breaker hasn't helped. Doubled checked wiring to the machine and am getting 208 across the leads and ground is good. Any ideas? Really hoping I don't need to use the 30 day return policy on this machine.
    Thanks!
    Will
    Apr 2009
    32
    Fixed this issue today after a few hours. I had the valve closed on the attached fire extinguisher tank. Somewhere in the machine there is a sensor for the line pressure. If it's zero it trips the breaker. Pretty heavy handed! I would figure there would be an on screen error if the tank pressure was too low, or it would put it in estop. Fully cutting the power was a surprise!
  1. NEWBIE to Citizen - G32 thread whirling on Citizen L520???
    By jmonty in forum CNC Swiss Screw Machines
    Last Post: 09-07-2013, 06:50 PM
  2. MAX200 tripping switchboard breaker
    By Welding Mike in forum Hypertherm Plasma
    Last Post: 05-24-2013, 02:36 PM
  3. Sare 750 with A2100 tripping main breaker
    By mgnbuk in forum Cincinnati CNC
    Last Post: 04-26-2012, 03:35 PM
  4. DM2800 5 amp breaker tripping
    By mp- in forum Dyna Mechtronics
    Last Post: 02-12-2011, 06:36 PM
  5. tripping the overload
    By machinehead1970 in forum CNC Machine Related Electronics
    Last Post: 10-26-2010, 10:23 PM
