586,655 active members*
3,175 visitors online*
Results 1 to 17 of 17
    Jan 2008
    241
    Grounding router spindle?
    Hello all!!
    I am looking for some info on how to ground my Bosch Colt router spindle.
    I use Mach3, and Gerry's awesome 2010 Screenset.
    I have a tool setter, which works great, although, I have to attach a grounded
    alligator clip to the bit before I set the tools.
    I have a couple relays on the way, and would like to wire these up to control
    the router and vacuum. The problem is the clip, and grounding the tool.
    So my question is, how can I ground the tool/spindle to avoid the alligator clip?
    and allow for automatic operation of the spindle after the tool change.
    Thanks!
    Machine as pictured:
    Attachment 210032
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    I think that your only option is to take the Colt apart and run a ground wire to one of the spindle bearings. Since the housing is plastic, you can probably grind a recess on the side of the bearing housing so that when you press the bearing back in, it holds the wire in place.
    Be aware that if the Colt has a short, this can be dangerous as you'll be able to get a shock from the spindle.
    Jan 2008
    241
    Hi Gerry,
    I just took the router apart, seems like the bearings themselves are isolated from the shaft too!
    (No continuity between the outer race and shaft) I'll need to make contact with the rotating shaft.
    I just bought a bunch of replacement carbon brushes, maybe I can devise something on the head of the router...?
    looks there is a good 1/4" or more space there...
    Attachment 210042
    Jan 2008
    241
    Here is a prototype I'm going to try for grounding the spindle.
    Not sure of the longevity this will have, but I got about 5 years
    off the original brushes, maybe I'll get the same for the grounding?
    From the pics you can see what I've done here... I took a small piece of Teflon,
    drilled a 1/4" hole in the middle(But not quite through)Then drilled a hole just
    big enough for the wire to pass through... I used the little cap off one of the brushes,
    and soldered my red wire to it, and fed it into the Teflon sleeve.
    I then slid the modded carbon brush into the top of the router, and into the sleeve.
    Slid everything together, and tested for continuity. and Wahlah! a grounded spindle!
    Dimensions of the sleeve:
    Length: 0.375"
    OD: 0.5"
    Everything seems to be working great... I'll post a follow-up if anything goes wrong!
    Trying to put everything together was a little tricky, but worked out.
    Cheers
    Chris
    Attachment 210086 Attachment 210090 Attachment 210092 Attachment 210096
    Attachment 210100 Attachment 210104 Attachment 210106
    Jan 2008
    241
    Update:
    Preliminary tests are great! and this is working out awesome!!
    I have a couple of hours run time now, with no issues.
    As part of my flash-up routine, I'll test the continuity of the spindle.
    I'll get a couple more hours on it, and check the grounding brush for wear.
    A little more automation on the machine! Yeah!
    Jan 2008
    241
    Well, time for another update.
    After about 100hrs, the carbon brush failed.
    I think the main problem was that I made it too small
    and the spring slipped over the brush.
    The idea is still feasible, so I'm going to continue playing with it.
    I'm designing a holder for a full size brush to be placed in the same
    location...
    Aug 2011
    215
    Hey Mogal. Here's what I did but it is also failing after running a bit. I'll try to come up with something else. Let me know when you solve the issue and I'll do the same.
    http://www.cnczone.com/forums/momus_...s_probing.html
    Jan 2008
    241
    Hello, I'm back at my design and testing phase again...
    I tried the A super-simple tool height setter! by RomanLini but can not get accurate results with different sized bits
    So I'm trying the carbon brush idea again...
    This time I wont be modifying the brush and will be making a bigger holder for it.
    I'll keep you posted!
    Jan 2008
    241
    So here is my (new and improved!) 3D Printed Carbon Brush holder. :banana:
    This time, it takes a full unmodified brush, so hopefully will last MUCH longer.
    So all I've done, is made the holder and enlarged the hole in the lid to let this just pass through.
    There is a spring that raps around the holder with the lid pushing down on it to keep it in place.
    I also enlarged the hole in the top of the body to allow the brush to pass through and make contact with the spindle.
    Sorry didn't take pictures this time around, but if need be, I'll take some for yea
    I include my ViaCAD file and STL if you wish to print them yourself!
    I'll keep a tab on my running hours again to see how long it lasts.
    Cheers!
    Chris
    Attachment 226842
    Jan 2008
    241
    Re: Grounding router spindle?
    Just wanted to post an update on the new setup here.
    I now have over 100hrs on this brush, and there is so little wear showing and I get perfect zeroing every time.
    Its working out GREAT!
    Highly recommended to those of you who would like to ground out your tool without alligator clips!
    Aug 2011
    215
    How's it holding up during these past few months where you haven't posted? I pulled my setup out because it wasn't reliable.
    What is the carbon brush? Is it just a solid carbon bar? It looks like it has serrations cut on the end? What are those for?
    What did you do on the other end that sticks out of the cover? Did you just wrap exposed wire on it? Would love to see another photo if you have it.
    Would also love to see a photo of the top of the spindle area (cover obviously removed). Did you have to modify this area at all?
    Jan 2008
    241
    This new setup has been 100% reliable.
    Not a single problem with the touch probe at all.
    I have about 200 hours on it, and there really isn't any wear on the brush.
    I'm super happy with this setup.
    The brushes I got off ebay, a set of 10 for $10. They are replacement brushes for the bosch colt.
    The serrations are how the brushes came, and I would guess its to help set the brushes quicker.
    For the wire connection, I took one of the little disks off the spring on the brush, and soldered it to the wire,
    and slid it through the 'holder' (hope thats making sense - see post #4 - on the old brush holder)
    The spring and brush slide into the holder and makes contact with the soldered disk.
    When I assemble everything, I kinda hold the brush into place as I line things up, pop the lid
    back on and replace the screw. The springs keep everything contact, and in place.
    I'm out on tour and wont be home till Mid Dec to take some better pics, so here's a cheesey paint pic
    Aug 2011
    215
    Cool. Makes sense. Thanks. How much would you charge for the 3d printed part and matching spring?
    Aug 2011
    215
    Haha, Mogal I just saw your private message now, after I had already asked the question above. Thanks for thinking of me and updating me back in June!
    I just adapted the carbon brush to the router. Continuity checks are all good. It's late and I'm heading to bed before turning the router on and doing some trial probing with it. I'll share pictures when I get them uploaded. I may have found a simpler solution.
    By the way, have you found any good probe bits? I'd like something with a 1/4" shank, but then necks down to a very small diameter and then has a tiny sphere on the end. Any ideas?
    Aug 2011
    215
    So here's what I did:
    1. I ordered the replacement carbon brushes for the Bosch Colt.
    2. After removing the router's cover, (first photo) I enlarged the hole above the spindle and drilled a small hole next to it for a screw.
    3. I bent a small piece of copper strip to form a right angle bracket and drilled a small hole in one of the legs for a screw (2nd photo).
    4. I soldered the bracket onto the frame of the carbon brush (3rd photo), and I also dropped solder in the top of the carbon brush's housing to prevent the top retainer from popping out.
    5. I cut off the pieces of the housing that are not needed (4th photo).
    6. I attached the assembly to the top of the router with a small screw (5th photo).
    7. I cut an opening in the top cover of the router to allow the assembly to protrude out (6th photo), and then soldered the ground wire from my CNC machine to the top.
    I now have electrical continuity from the tip of the cutting bits all the way to the top. It took me about 30-45 minutes and I'm looking forward to trying it out!
    Aug 2011
    215
    So far so good! I've run the router for longer than it took to wear out my other attempts. These carbon brushes seem to be very promising. I have not taken the router cover off yet to inspect, but I'm assuming all is good. How long do these brushes last for? I'm concerned about a buildup of conductive carbon dust inside my router, and more importantly for health reasons. I've never dealt with these brushes before. Anyone have a clue?
    Nov 2020
    I know this is an 8 year old post but I needed to thank you guys for all the work you put into this. I've been having a problem with the router on my CNC building up a static charge that has ended up affecting the Z axis steps in the middle of jobs. I've also been wanting to setup gatorless leveling so this is a 2 for 1 win for my setup. Will be testing it out this afternoon, fingers crossed!
  1. Grounding or?
    By warrenb in forum Maintenance DIY Discussion
    Last Post: 02-28-2014, 03:39 PM
  2. Grounding CNC Plasma
    By z28 in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 04-03-2013, 03:36 PM
  3. Grounding the DC-K40
    By neptr in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-28-2012, 06:00 AM
  4. Componet Grounding
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 12-29-2009, 07:55 PM
  5. grounding Q's
    By anthony in forum CNC Machine Related Electronics
    Last Post: 05-14-2005, 11:24 PM
