586,108 active members*
3,173 visitors online*
Results 1 to 6 of 6
    Oct 2013
    153
    Lower case letters in G-code
    Hi all is anyone know how to prevent lower case letters and special characters in G code
    Oct 2013
    64
    What do you mean by prevent? It's should be part of your code and there are lowers and uppers to help us.
    Sent from my Nexus 4 using Tapatalk
    Oct 2013
    153
    What I mean is that my machine won't accept lower case letters so I want all my comments and instructions in the G-code become upper case . Is there anyway to do that ?
    Oct 2013
    64
    If you can edit in wordpad, you can cnrl-a that is select all and change the your fonts to lower case.
    Oct 2007
    499
    You can edit your gpp file to convert all letters to lower or uppercase. Try this
    string_variable = upper(string_variable)
    Oct 2013
    153
    The upper function did it
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Replies: 0
    Last Post: 11-13-2013, 06:54 PM
  3. Transfer lower case letters
    By Zigar in forum Okuma
    Last Post: 01-03-2008, 02:43 AM
  4. G-Code letters What are the definitions?
    By CADkathy in forum G-Code Programing
    Last Post: 08-05-2004, 12:37 AM
