SteelTailor plasma power source stop working because of low air pressure how to do?
While cutting the SteelTailor CNC cutting machine plasma power source stop working because of low air pressure, how to restart cutting from the point in stop cutting.
Ans:First pls make sure that your ARC FEED BACK is set in SteelTailor cutting machine CNC controller. If this parameter is set one if the plasma stop working the SteelTailor CNC will also automatically stop movement.
In this cause you can just press PREHEAT key on the CNC cutting machine controller key pad to restart cutting and movement together.
If the SteelTailor portable CNC cutting machine plasma power source is old model and you are not using ARC feedback, then Press RED key to stop the machine movement. As the CNC cutting machine movement come to a paused a four options will appear. Press BACKWARD [F6] and the SteelTailor cutting machine will start moving back along the shape it was cutting. As it move back and reach the point where it stopped cutting press RED key to stop the movement. Next press PREHEAT key on the controller keypad to restart cutting operations normally.
SteelTailor--The world leader of portable CNC cutting machine
www.steeltailor.com
