High Speed Spindles
Alrighty then... I will be in a market for a new machine soon. I already have my Hurco for heavy work. I want a machine with a high speed spindle. The Torus has the best deal in hardware and envelope, but a 5K max spindle is not enough. The Tormach's 10K spindle is better, but the hardware comparison doesn't add up. The Syil X4 or X5 in the Speedmaster configuration is getting there with their 24K spindle (or optional 35K) spindle but the work envelope is just a bit too small.
I don't want to run a companion spindle (flex, setup, service life, etc). I don't want to run a speed multiplier (flex, cost, not fast enough for the price).
Right now I do high speed stuff on a Taig. I'm not kidding. I put a router motor on it and let it fly. It will remove material at a faster rate than just about anything else with tiny cutters.The Taigs problem is it just isn't up to high duty cycle and long cycle times. I need to take it apart and adjust about every 4-6 hours of cut time to maintain passable tolerances.
Wadda ya do? I can't afford a Haas or Fadaal.
What I want is something about the size of a Torus with a 24K-35K ER spindle and the weight and stability of a cast iron machine. I'm almost at the point of trying to build a concrete filled steel machine.
Bob La Londe
http://www.YumaBassMan.com
